needing pointers?
garyr2602
Hello, I'm new to the outboard motors an I need a little advise, I jst purchased a 1987 28hp evinrude outboard motor on a pontoon last weekend, put it in the pond an it fired right up an had a good stream coming out the water discharge all day went out on Sunday working good then second half of the day I lost the stream out the discharge hole, I'm wondering if I sucked silt threw it an pluged it up, not sure how long motor was sitting before I took it out so I bought a new water pump kit for it to put on, is there any other way of flushing motor besides the Mickey ears an barrel of water perhaps threw the thermostat or so? Any advise would b appreciated on what u think problem might be or what I should check
F_R
Honorary Supreme Mariner
So, have you installed that new pump kit yet? If you don't know the history of the motor, you certainly should do it. Consider if it might still have the original in there it would be 28 years old. Way, Way past due for replacement. That is far more likely to be the problem than "plugging up". If you think something is plugged, before you go looking for something major, blow back through the tell tale. That is a small hole, and most likely first to plug. Let's hope the old impeller hasn't destructed. That will plug things up.
BTW, you can't test a water pump by running on muffs. When doing that, hose pressure will make water flow through the system, even if the pump is worn out. ​
garyr2602
No I haven't made it to the pump yet hopefully Saturday morning. The tell tale ur talking about is that the water discharge line coming from the powerhead? Ill change that pump an ley u know what I come up with
garyr2602
I changed the water pump today an still not getting water out the tell tale, should I take the thermostat out an see if I have rubber pieces in there from old propeller (old propeller was almost completely gone) any other places I could check for blockage from rubber? Thanks
jrs_diesel
Wouldn't hurt to take a look inside the thermostat at this point to make sure there's nothing stuck there, especially since you found pieces. If you have a source of compressed air, use that to blow air into the indicator hole. I just ran into this issue of the indicator not working on my 9.9 and shooting some compressed air into the indicator cleared it right up.
BTW, that is an impeller inside the water pump.
hardwater fisherman
When you put the lower end back on did you get the water tube seated in the pump? With the lower unit off you can run some high pressure water through the water tube. And see if it comes out through the top. If you said the impeller was gone then most likely the rubber is jammed in there somewhere. The thermostat and housing would be a good place to check for pieces of rubber.
garyr2602
Thanks for the info. I blew air threw both ways an took some weed water line an ran threw tell tale an flushed all with water put it back together an its got a good stream of water out tell tale so I think I got it. The other issue I have now is the motor won't stay running when I go to shift in reverse an I know its nit good to start in gear but it wont start I reverse either any ideas? Motor runs good in drive an will idle at low rpm in neutral but nothing in reverse
garyr2602
As soon as I go to shift in reverse it stalls out, could it jst be the throttle needs adjusted?
jrs_diesel
In the water or on earmuffs?
If on the water, then yes, the idle is likely set to low. I don't think you want any lower than 650-750 RPM in reverse.
