Needing a broken spring/fuel
Brokenline
Cant seem to find a diagram that tells me what the name of this spring. Can someone help I need to order a new one as mine broke. Bottom of black arm. Sorry I am a new to repair of outboards. Also is there a fuel pump, the motor runs if I keep pushing the bulb but runs out shortly after pumping.
Vic.S
What engine? Make, hp, year and model number ?
Your fuel problem may be due to a defective pump or due to air in- leakage into the fuel line. Fuel line connector the prime suspect
F_R
So you have about a 1972 to 76 model 20 / 25 HP.----Yes it has a fuel pump.----Find it on the starboard side of the block.----Follow the hoses to it.----
385653 for assembly with spring.----only about $65.--------It prevents recoil from working if motor is in gear.---A safety device.
Brokenline
70s 25 hp johnson
F_R
I used parts book for 1970 25hp model 25002. Similar motors of the era, such as 20hp also used it.
