Need wiring help with a carolina skiff gauge!!
wilson750
I just put a larger motor on my 2001 carolina skiff semi v 17'..The one gauge has some lights for warnings, oil,temp,and some other warnings..I had to cut the plug and the new motor did not have a plug to plug into that gauge..Is there any where i can get some info on what each wire should go to on the new motor?
Thanks
Re: Need wiring help with a carolina skiff gauge!!
Thanks
Ayuh,... It'd be kinda nice to know what the old motor was, what the new motor is, 'n What gauges yer talkin' 'bout.....
wilson750
Bondo,
Old motor was a johnson 50hp 2stroke, 2001,new motor is a 75h mercury 2stroke 2002..The gauge has all the warnings on it..It is tandard on a carolina skiff im sure..
Sixmark
Master Chief Petty Officer
Standard can mean multiple different suppliers of gauges, pics of the front and rear of the gauge will do a lot more for your cause than saying standard on a Carolina Skiff.
You also switched from one manufacturer of motor to another, and they are different animals.
