Can anyone help me find a wire harness for 1995 150hp Johnson Ocean 2 stroke motor or will other year wire harness fit. If you know of someone selling one please send me the link
I would guess a 1992 - 1995 harness would work... they also made and sell an ADAPTER HARNESS that would allow you to use a harness from 1996 through about 1999..maybe even later.... the only difference probably being the terminal ends have different connections... the functions of the motor and control are all the same....
controls are what give throttle and shifting capacity to your boat from the motor...it usually is where you start the motor from as well...
the harness PLUGS INTO the control!! they need to be compatible!!! so if you could tell us what year your control is( assuming it is OMC...ie Johnson or Evinrude)
well that looks like a POST 96 control....so will probably need to find an adapter as well as a harness( unless they have started making a harness that has the red plug on one end for pre 95 motor, and duetsch plugs for the control)....
well the control you posted a picture of that you say you have clearly has the deutsch connectors on the end to connect to any harness you get... and the harness you posted that you say you need, clearly does NOT have those connectors on it....... I am pretty sure if you have a 1995 motor, and you have that control you posted a photo of, then you want the link I posted....it is a pre95 motor to post 96 control harness adapter. good luck
oops looking at the listing again the harness adapter is actually reversed from what you need....it connects a post 96 motor to a pre 95 control...sorry......but remember your control has duetsch connectors, so your harness will need that style connectors on the end!!!
