Re: Need to select prop for 83 CAPRI - force 85
Well, i got a different prop.
Its a michigan prop, i cant find it on the site.
On the side it has the number Z873, and something else on the other side that i can't make out at all, it reads "1 something something something C"
on the inside, where the thrust bearing goes i can read 'MICHIGAN' 1042 and K591
unfortunately none of those parts of serial numbers match with my prospective propellers.
This prop seems a little bigger, heaver, maybe an fraction of an inch wider. It looks like it was on an engine that put the exhaust through the hub.
The strange thing is that it gets me to the same speed as the original. Actually it little lowered the top end by 1 or 2 mph (at 28 to 29 now) My tach is still on order so i dont know exactly what its doing but the motor doesn't seem to wined up as much as it did before, and strangely it feels like the new prop gives me much better accelloration from zero to 20mph, the boat will take off at a 45 degree angle.
Im starting to think that no matter what way i spin it i still have x amount of HP thats going to get me to x speed. I've tried all 4 positions of the pin (power trim, ha) and it seems to be planing ok. I did a compression check on the engine when i purchased it and all they cylinders where in spec. Could i be suffering from some timing issue or something to that nature? it really only gets the lead out when i put the throttle down past the half way mark (when it starts moving the ignition advance lever)
basically im out of ideas at this point... maybe 30mph is just its max speed?
