need spark plug torque specs for 1989 85hp Force
Quastello
for some reason I cant find anything on here for torque specs for spark plugs on my 85hp Force thanks
Jiggz
The recommended torque is 18~21.6 ft-lbs if you are using the NGK plugs. I presume the same also applies for the Champion plugs. Personally, I always set them at 20 ft-lbs and never had any problem.
