NEED SOME PROP HELP PLEASE!!!
ILOVEBEER
Hey guys, I have posted another thread in the engine forum stating that I am having a problem getting my boat on plane with a heavy load at the higher altitude lakes. The general concensus is that I need a different prop so I am hoping I can get some insight here. So, here is what I have:<br /><br />#1. Drive - 1998 4.3L EFI Merc Alpha 1<br />#2. Current prop - Merc. Vengence SS # 48 16316A45 19P<br />#3. Current RPM - 4850<br />#4. Hull - 1998 Sea Ray Sig 190 fiberglass<br />#5. Jack plate - not sure what that is.<br />#6. No tabs/foils<br />#7. General uses - The prop I use now works great for sea level uses. I am looking for another prop for use at higher altitude lakes (4800' MSL). I normally have a full load of people and like to wakeboard. I would like something that will pull a boarder out of the water easily and gets on plane quickly when cruising. Top speed isn't a huge issue but I would like 35-40 mph if possible.<br /><br />Thanks for any insight, advice, or recomendations you have.<br /><br />-Beer
walleyehed
Re: NEED SOME PROP HELP PLEASE!!!
I figure about an inch less pitch for every 1500ft MSL. (to understand MSL vs. AGL, I'll assume you're a pilot?)<br />I would highly recommend you take a serious look at smart-tabs as well.
ILOVEBEER
Yeah. It's habit, sorry. However, I assure you, I only love beer when I am not working. :) <br /><br />So those numbers on my current prop, what do they mean? Is the 19P mean pitch? Isn't pitch measured in degrees not inches? If not, what is an inch of pitch? I was looking at the Merc prop finder and it says you need to know the outdrive gear ratio. Where can I find that out?<br /><br />I'm so boat stupid.
walleyehed
Yes, the 19P is pitch, and yes, it's measured in inches...we measure Rake in degrees.<br />The 48- indicates Merc, and the rest of the numbers are style and what it fits.<br />I punched some numbers on Merc's new prop selector, and it says you should be in the 17P range with some 16's listed.<br />Are you sure about the tach and what is your top-speed and is it by GPS or other means?
ILOVEBEER
Thanks for the info Kenny. I have not ran my boat with a GPS yet but I will this weekend and I'll get back with some more solid numbers. Thanks for your patience. <br /><br />BTW, you must also be a pilot, no?
ILOVEBEER
Hey guys,<br /><br />I took the boat out with the GPS and here is what I got:<br /><br />1) 3 people in boat<br />2) Elevation 937'<br /><br />46.8 MPH @ WOT. WOT = 4920 rpm (on timing gun). Manufacturer WOT recomendation is 4400-4800. <br /><br />I had a feeling my tach was off so I used my timing gun and sure enough they differed by 200 rpm +-. My tach seems to be ok from about idle to 900 rpm and then it starts to read low. Any ideas?<br /><br />Thanks
ILOVEBEER
What do you think Kenny? Looks like I am exceeding the WOT range with a 19. Will 100 rpm damage the motor? I am thinking a 17 pitch for my high altitude prop. Any ideas?<br /><br />Thanks
walleyehed
100 won't cause any issues, and yea, I think a 17 would be a good choice for 4800 based on what the 19 is doing at 900+.
