Re: Need some hull repair advise please!
I'm just a newbie around here, but I'd like to see the experts response to this also.
this is my best GUESS
1 mold a heated piece of waxed plexiglass around the bottom of the boat where the hole is, a couple inches larger than the hole in all dimensions
2 remove the foam above the hole inside the boat, grind and feather the fiberglass around that hole (from inside the boat)
3. wax the snot out of that piece of plexiglass, and then clamp/duct tape it to the hull on the outside.
4. startin with a piece of resin soaked glass cloth just bigger than the whole, lay it in there, and repeat, with each piece of cloth being bigger in all dimensions than the one before, untill your last piece of cloth fills the entire feathered bit.
5. pull off that waxed plexiglass after the glass+resin has set..
6. sand and fair from outside...
am I close? experts?
