need some help with my project
betayv
Im trying to replace the two flooor side pieces and the center piece with fiberglass what kind of material should I use?, how I bond the two side pieces with the existing floor thanks for the help.
18ft3hull
Re: need some help with my project
are those factory storage hatches ?? if so why get rid of them just make new ones to fit
betayv
yes they factory the center is the one for the gas tank I really never used them and I want to put carpet on the floor that is the reason I want to close them with fiberglass.
18ft3hull
if you want to carpet it just cut plywood to fit the openings glass both sides of the ply to seal it and carpet over the top if you make the carpet removable (like velcro it down) clean up is easier and you could still use the hatches
jonesg
If you cover that center hatch, how will the tank compartment get vented?
Rugs in boats, bad idea.
betayv
for the center hatch I only want to replace that wood piece with a fiberglass piece the ones I want to close is the two on the sides.
betayv
anybody? I want to know what is the best material to do it?
bskye85
Cut up some Marine plywood, then glass over it. Read a few pages of Oops! hull extention thread...All the answers you are looking for on glassing are there....
