hi there and thanks for help, I have a 22 feet cruiser barnegat the gas tabk is in the center of the boat and under the gas tank is a piece of wood plywood the size is about 5 feet long x 3 1/2 feet wide is rotten and and very bad shape the rest of the boat is looking good, I took some core samples and the rest look good, Im ready to fix that piece I have marine grade plywood ready to be cut on the exact size and I bought some epoxy resin I need to buy cloth? or not, if so what type of clothe you guys recommend, Now my really question is in case that I need to use cloth I have to give a first hand of resin to the plywood, then lay the cloth and put some more resin thanks.
