need some help please
recman84
I have a 2007 Tahoe Q6 SF. when we bought the boat I did not receive an owners manual. I know my blower fuse needs to be replaced but I have no idea which fuse it is? I also have a trolling motor that came with the boat that is not working. Is there a fuse that could have possibly blown for it as well? The battery for the trolling motor is fine so I know that is not it.
danpar
Re: need some help please
Can you not trace the wire from the switch to the fuse?
danpar
Could also double check the battery connections.
SKGrice
I would just check all the fuses. If you know you have a blown fuse it shouldn't be too hard to find. If you don't find one blown check your connections like danpar suggested..
recman84
thanks for the suggestions. i appreciate the help
