Need some help on a Johnson 50ESL72C 50 HP engine
MicahSmith
So I am a bit of a newbie when it comes to outboards but i have gotten an incredible deal on a boat with a 50 HP 1972 Johnson outboard. It was in rough shape and has been a fun project for me to learn the ways of outboard engines. All in all, I have replaced the starter, timer base, powerpack, and starter solenoid. I have also rebuilt the carbs (cleaned a bunch of junk out). So I really have two questions:
1. I removed the shift switch per my dads suggestion because it was completely shot so Id have to replace it anyways. Just so i could get it to crank i spliced the two white wires (start circuit) together. Is there a real problem with doing this? Ive heard something about the motor being stuck in the forward gear if this switch were to go out? Thanks for the help!
2. This is my big problem right now, first of all I can get the motor to start after warming it up and using a little starter fluid haha. However, when I do start it up, it revs up to about half throttle and stays there prop spinning and all (maybe because of the wire splicing I did in question one?). The problem is, once it turns on, my key wont turn it off. I have tested it with the multimeter and it does a fine job of starting the engine but I have learned that it may not be grounding? The only way I can get it to just shut off is removing a plug wire. (Which I never do with my bare hands haha)
I know this is an old engine but I REALLY need help as I need to sell this motor and buy a smaller one for my little fishing boat. Any help is greatly appreciated/ general knowledge of how this system works.
Thanks so much!
Micah
F_R
Honorary Supreme Mariner
1. The white wires are for the start-in-neutral-only portion of the shift switch. They have nothing to do with shutting it down or shifting out of forward. HOWEVER you say you removed the switch. That certainly explains why it stays in forward gear.
2. The key switch kills the ignition to shut it down by grounding the black with yellow stripe wire.
I agree, I HATE being shocked, and those plug wires will knock a guy right out of his undershorts.
MicahSmith
Thanks for the reply! only problem is I don't have a black/yellow wire coming from my keyswitch. I have a black/yellow wire coming from the male side of the plug on the wiring harness but not from the controller. Also, one of the M posts on my key switch does not have a wire connected to it and Ive heard that the key switch grounds acriss both m terminals to kill the engine?
