Need some help OMC 5.8 Cobra no spark
Status
Not open for further replies.
daddybx
Hi All,
First post have used forum to fix many things just great people on here. so heres my dilemma
1989 Bayliner Ciera 2455 5.8 OMC
Wen to pull boat out of water and it died started up the start stayed engaged. Shut down batteries got boat to house.
noticed fuel flowing from card so I have so far done
New Carb
New Points
I have gapped Points .20
Plugs are .30
I have power all the way to the Points But nothing to the Plugs??
So I then replaced the Solenoid assist ( top motor stern side)
and New Battery
NADA
Carb gets Fuel
anyone have any thoughts? Much appreciated
Thanks
Don
daddybx
Re: Need some help OMC 5.8 Cobra no spark
Ok had a mobile mechanic come out well that was a waste knew something was wrong when I had to tell him the proper Gap lol
Anyway bought a new starter put it in tonight turned on batteries and the starter is engaging immediately???
What can cause the starter to stay engaged?
New battery
new points cap/rotor
Starter
Solenoid Assist (slave)
Please any advice
THanks
Don
DBreskin
Sounds like an electrical problem, maybe a short in the starter circuit or ignition switch?
Don S
I'm going to close this thread for right now. You have another thread about the starting problem. Once you get the starting problem fixed, your spark will probably come back since that solenoid you have that is wrong also puts power to the igntion system when starting.
Status
