need some help guys
JEFFBUZZZ
5-13-12 just bought a 2012 suntracker 20ft fishing pontoon with a mercury 60 h.p big foot took it out yesterday with 3 people on board could only get 5600 rpm at wot top speed was 22 mph .with 7 people on board wot was 4800 rpm at 14 mph the prop is a 11 pitch .can i get any better top speed by changing prop .if i go to a 10 pitch will it only get better with heavy load ,and loose top speed with light load ,iam a prop dummy so i might be asking dumb questions . 5-14-12 went to bass pro today ,they recommended a 9 so i swapped the 11 out for a 9 will try it tomarrow on the river and go from there ,i have to give bass pro credit they have been great after the sale if i dont like the 9 i can go try different props till iam happy ,i thought that was pretty cool of them ,not alot of places would give you brand new props to try till u find one you like . 5-15-12 ok here is the latest went out yesterday only four of us on the boat with the 9 pitch it got out the hole very fast but i lost speed badly went from 22 to 15 mph and rpm was 6300 at wot ,could not trim motor up any with out losing speed if i trimmed up any i would lose speed fast .there has to be something i can do to get max speed with max rpm .iam only shooting for 25 mph ,thats what i told bass pro i wanted this was the motor they recommended for that speed. iam 3 mph off with the 11 pitch .should i just settle for the 22mph or is there something i can do
coastalrichard
Re: need some help guys
Sounds like the 11p was the best so far. You're never gonna be a speeding threat on the lake;)
rickdb1boat
22 MPH is doing good with a 60 HP. I wouldn't look for too much more. You could try a 10" pitch that should put you right around 6000. The norm is to prop toward the max recommended RPM's with a light load. That way when you get a heavy load onboard, your engine will not be lugging along
lncoop
Sounds like the 11 is the ticket.
EricJRW
Yep... 20 is about my max too... Details in sig.
BobGinCO
23 is my max with a 115 (which gets about 90 HP at 6,000 feet elevation). That's probably because I have 3 24 foot pontoons in the water, with no lifting strakes.
MH Hawker
You may as well lean back open a drink and relax and enjoy the ride.
