I have 2 moeller side mount gas tanks and the fuel pickup tubes were extremely thin wall vinyl (or so iam told) and have both turned to chalky yellow plastic and disintegrated (alcohol in the fuel iam told) I picked all the bits out of the bottom of the tank, but now I have no pickup tubes, the fitting is a barbed one with threads on it where the tube goes on it then it screws into the tank, the problem is that all the vinyl tubing I can find is too fat walled to fit through the threaded hole, so either I have to find some thin wall 3/8 tubing or I have to find something else that will work. Or I have to dump 2 $130 tanks because 3 feet of hose **** itself.<br />Need to get new screen ends too.<br />I wonder if the manufacturer can send them to me.<br /><br />This is the port tank:<br /> http://www.overtons.com/modperl/overtons/detail/pdetail2.cgi?r=detail_view&item_num=39529 <br /><br />and the starboard one of the same type too.
