Need reference pictures of 120 hp.
Tj Hooker
Hi, I need reference pictures of my 120 hp Force 1994 to reassemble it after a rebuild, thanks, TJ
roscoe
Re: Need reference pictures of 120 hp.
What you really need is a Clymer or factory repair manual, or you're gonna miss something. The torque numbers alone would be worth the cost of the manual. The assembly tips are priceless.
If all you want is a parts diagram, go here:
mercruiserparts dot com/selectModels3.asp?type_id=FORC
zoe'sdad
TJ, I have a '97 Force technicians maunual which covers your engine. It will not tell you how to acutaly do the work but has diagrams showing how the motor goes together, identifies parts and gives the correct torque for bolting everything back together. Send me an e-mail with a fax number and I will fax the diagram over.
