need quick answer"sugar in gas tank"
Capn Mike
Re: need quick answer"sugar in gas tank"
Beernutz is right: since sugar will not dissolve in gasoline, it will absolutely not harm an engine (but it will plug up a fuel filter if it gets that far, just as will any other solid substance). <br /><br />Years ago, I attented a school for auto claims adjustors and the sugar in the gas tank myth was part of the curriculum. We poured some sugar in a jar of gasoline, and 3 weeks later, it still had not dissolved. Further, one of the instructors took the air cleaner off a new car and poured sugar into the carb. Clouds of black smoke poured out of the exhaust (this was pre-catalitic converter days) until finally enough was poured in to stop the engine. After several other indignities were performed on that car, the engine was torn down. Other than excessive carbon on the spark plugs, there was no, that's NO, damage to the pistons, the rods, the wrist pins or the ring grooves, or any other part of the engine. :p <br /><br />This is supposed to be a forum for knowledgeable people to help, not pass on old wives' tales from their childhood.. :rolleyes:
cloumar
That is all right guys, sugar will not disolve in cold liquid like gas- it will like in hot coffee or tea. Worst case it will clog up the carb and small orifices in fuel system before it reaches the combustion chambers (cylinders).<br /><br />Believe a car Tech.<br /><br />Mario
Beernutz
The reason it disolves in coffee or tea is because of it's chemical composition. Sugar is nothing but carbon and water. It's the water in coffee & tea that makes it work. They don't even have to be hot. Heat just speeds up the process. It won't disolve in gasoline or oil.<br /><br />Sugar melts at 160C - 170C. That's 320F - 340F. (Sorry, I don't have a degree sign on this keyboard.) If anybody tells you it melted into the oil, ask them how the oil got that hot. I wouldn't want to drink coffee that hot, either.
