need points gap for a 1964 90hp Johnson Meteor. Anyone help?
Tim Frank
Re: need points gap for a 1964 90hp Johnson Meteor. Anyone help?
The old gap is .30
should I use that?
Not sure what you mean.
If you mean that you are R&R points, and measured the gap on the old points and it was 0.030", the answer is no. That is normal wear on the heel that has opened up the gap.
I have never run into an OMC with points that was not spec'd at 0.020"...actually make that an OMC with magneto ignition.
If you mean that there is something on the flywheel or engine somewhere that says ' set points to 0.030" '...of course go with that...I am speaking from my experience only.....I sure haven't seen them all...:)
imzame
Im a newbie Tim. I mean the points under the distributer cap. Is that the R&R Points?
Tim Frank
R&R = removing and replacing ;)
imzame
Thanks Tim.
Will the new points at .020 make the engine run better?
HighTrim
Not to bud in on Tim here, but you are replacing those points correct, not just regapping them? When you do ensure they are EXTREMELY clean, no fingerprints, etc. Dont use sanpaper on them either, it wont file them square, and you wont get good spark. It also leaves grit on the points, disturbing contact. Points file only or replace. I clean mine with acetone after Im done adjusting, and test with a meter to guarantee they are opening and closing when they should. If you want help with this, and have access to a meter, let us know.
As far as will it run better, heck ya. ;)
Tim Frank
Thanks Tim.
Definitely, if 0.020" is the correct value, and they were 10 thou over that. Cleaner spark, easier starting, better fuel economy, smoother running as related benefits.
As I said, I THINK it should be .020, but there are some folks on here who can say "it is ___".
imzame
is the paper square that came with the point for sanding?
imzame
High Trim,
How do I use a meter?
AlTn
doesn't this motor have the battery/points/coil ignition..like automotive type of that era?
seahorse5
The old gap is .30
should I use that?
the plugs should have a .030" gap but the points should be .020" Old time mechanics may remember being taught at the factory training schools that new points should be set at .022" as the rubbing block will "wear in" and they will be at .020" after a few hours of running.
