need peanutbutter recipe (slow cure)
twkjr 1250
i' am about to get my new transom in place. was going to use pl ,however my transom is warped and afraid pl will not hold as good as peanutbutter will . will need alittle more time to clamp the kinks out . just did a dry run went real well , i still want to be prepared for the worst .
JAFO1
Re: need peanutbutter recipe (slow cure)
Aerosil:Resin:Milled fibers Some call for glass bubbles, but I didn't use them. Also, instead of milled fibers, I used chopped up CSM. Basically the same thing, just longer fibers. Then catalyze with MEKP9. ONDRVR broke down the cat ratios in my thread, "1986 Skeeter Resto." Mix the ingredients very well, then catalyze. An old beater in a drill works well (taken from oops! 'hull' thread), unless you are using long glass fibers.
I'm not sure if PB is the right application here. You will have 10 to 12 minutes max to work. I think PL may give the working time you need.
Woodonglass
On Second reading, do you mean your transom is curved? Warped and curved are two different things. Curved is ok, Warped NOT ok. PL can be used but, and this is my opinion only, I believe resin peanut butter, especially EPOXY peanut butter, provides a much stonger bond especially if you grind the outer skin to fresh glass.
Pics of your transom work would sure be nice!!!!
I'm just sayin...:D
twkjr 1250
looks like i'll have to speed up the pace . I don't feel comfortable with pl in this situation thanks guys .
jonesg
Thickened poly resin cures very fast compared to straight poly resin,
I wouldn't want to use it if theres a problem with alignment.
