Need parts for a 1990 Gamefisher 15hp.
Bearcamp
I have a Sears Gamefisher 15 hp, 1990. I tried locating a fuel pump dia and a primer buld through Sears with no luck. Am I doing something wrong? I gave the Model number of 255.581503 but comes up they can't find a model number like that. Where else might I get? I know Napa has Force parts, but the model number (Sears) isn't in their book, I looked. Just Force numbers. Is there a way of a crossover or something.
JB
Re: Need parts for a 1990 Gamefisher 15hp.
I would start your search by posting in the Other Outboard forum, Bearcamp.<br /><br />That is where Sears wrenches go to help.<br /><br />Moving this there.
ratracer
Originally posted by Bearcamp:<br /> I have a Sears Gamefisher 15 hp, 1990. I tried locating a fuel pump dia and a primer buld through Sears with no luck. Am I doing something wrong? I gave the Model number of 255.581503 but comes up they can't find a model number like that. Where else might I get? I know Napa has Force parts, but the model number (Sears) isn't in their book, I looked. Just Force numbers. Is there a way of a crossover or something.
You got one of the digits wrong, if you look under model @ 225.581503 it should come up as a 15HP Gamefisher outboard. Since that's a 1990 model it was manufactured by Force.<br /><br />Based on my limited experience the Sears part # for Force-manufactured outboards are either identical to the Force part #, or they add/subtract a character from the front of the Force part # to create their own. <br /><br />If you don't have your owners manual you can go to http://www3.sears.com and type in that model # then select the appropriate drawing to get the Sears part #. Or, you can go to <br /> http://www.mercruiserparts.com/selectModels2.asp?type_id=FORC and look up the correct 15HP outboard to get the Force part #. My guess is that the Force parts would be somewhat cheaper.
