need more info on Clinton Apache
bkoinzan
I need to order a manual for my Clinton Apache but I dont know the year, horsepower, air or water cooled or both. The only numbers I can find on the engine are as follows;<br /><br />Clinton Engines Corp.<br />Model #J9 1106 B<br />Serial #099219<br /><br />Thanks a bunch!<br />BJ
steelespike
Re: need more info on Clinton Apache
J9 is a 5 hp at 6,800 rpm.It has a Clinton aircooled power head with a water cooled exhaust leg.It is critical the leg is properly cooled.<br /> A mist of water should come out of the little outlets on the rear of the leg.I cant tell the exact year but my info indicates at least 60-68<br />with a AJ9 and BJ9 in 69.It may be hard to find a manual specific to Clinton as they have been out of business for some time.There are aftermarket manuals that cover a number of brands.They may be available here at Iboats or a number of places on the web also check eBay and the library.<br />This number may be some help 563-652-2411 they<br />have Clinton parts and may have info as well.<br /> Good luck
sea king 5
Dued:(Steelespike) I don't know you,I do know the differance bettween Fool and Ignorant,If you have never looked it up I suggest you do so,and at that point if you still don't know what it meens then take a good look in the mirror,<br />Car, Truck, Van, Sled, Lawn mowers, Weed eaters, Blowers, R/C Model airplanes, R/C cars,ect,all have one thing in common.???????? Gas powerd air pumps, Gas goes in,goes boom,comes out,gears go round and round,as long as you have oil!!!<br /> -----------<br />Sea King 5<br /> "When you work on anything and have the manual and refuse to look at it and read it,you have an Ignorant mechanic.<br />When you've tried it over and over and over and over and over the same way,and it still won't work,You may have to check into the looney bin,certified FOOL!!!!!!" NOT YOU OF CORSE.
