Need input Please!
bigphish1978
Have a early 70's Reinell w a merc. Gm 250. Got floided up to the starter.. now all electrics work but when you turn the key it does nothing. No noise, no solenoid click, nothing! Battery is good. Tried new solenoid and still nothing. Any help is much appreciated!
bigphish1978
I hadn't replaced the starter or the solenoid on top of the starter. That is next on the list. Thanks for looking
NYBo
Welcome to iboats!:welcome:
Before replacing parts, determine whether you have power to the solenoid when the key is turned to the Start position. Was the starter actually submerged?
Silvertip
Honorary Supreme Mariner
Test for voltage as follows:
1) Battery voltage (measure across the battery posts (not the terminals on the cables). 12.6 volts = good
2) Measure voltage between engine block and the point where the positive battery cable connects on the engine. 12.6 volts = good
3) Place positive test lead on the small solenoid terminal fed by the ignition switch. Turn key to START. 12.6 volts = good. If no voltage or very low voltage, bad ignition switch or wiring. Verify power at "B" terminal on ignition switch.
4) Place positive test lead on the large solenoid terminal feeding the starter motor. Turn key to start. 12.6 volts is good and at that point starter would be suspect.
If 12 volts not present at starter side of solenoid, THEN replace solenoid.
The trick in troubleshooting electrical is follow the juice. When you lose it you found the problem. The path is positive terminal on battery, to solenoid, out the solenoid to the starter. The solenoid is energized by the ignition switch which gets power from the battery, sends it to the "S" terminal from the "B" terminal on the switch.
bigphish1978
Thank you very much for your replies and welcome! I will start testing parts this week. Thanks again for the time.
