Need Info on Johnson 10hp Model QD-24B
kdfarmer
Looking for a repair manual to finish up a repair on the lower unit. I was given a box of parts with the disassembled :confused: lower end in it. I've been a motorcycle mechanic many years ago but this is my first outboard so any tips for the new kid on the block would be greatly appreciated.
alcan
Re: Need Info on Johnson 10hp Model QD-24B
Hi Keith<br />You can order manuals from Iboats at the bottom of this page. Their prices are fairly competitive. Or you might be able to find a copy at your local library. These lower units are pretty stright forward. You should have no problems if you have the book. You may want to buy a special tool from your omc dealer. this tool is a punch to remove the shift rod seal bushing. This will allow you to replace the o-ring. I think they only cost $10 or so.
rickdb1boat
A little more. If you didn't know, QD-24 is a 1963 Model 10 horse Johnson. According to the spark plug chart, you should be using champion J6C plugs gapped at .030. The lower unit should be fairly straight forward. A Factory Manual and Parts catalog(Good Idea) can be ordered from the link below. Good Luck,<br /><br /> Manual
Joe Reeves
Ken.... If you're in a hurry, fire me off a line to my address below. Remind me what you need and the year/hp of the engine. I'll scan that L/U parts page for you.
kdfarmer
Thanks for all the responses, I needed the year so I could determine which manual to get. Also I was looking for any gotcha's that I may encounter on the rebuild so I appreciate the heads up on the punch. :)
