I blew a piston rod on my 86 Johnson 15 hp, I found a replacement 1991 9.9 powerhead, I know they are compatible as I have the 9.9 powerhead already you ted, my only problem I'm having is the wiring isn't matching up, the 9.9 has a different harness and power pack. I had to cut a brown wire going from the tiller arm of the 15 that I believe is for the Killswitch but I can't find the matching with from the 9.9. anyone have any ideas what I can do to get the electronics working. The 15 is model e15rcde the 9.9 is j10reir [h=1][/h]
