NEED HELP!
amaziing1
2005 johnson...... wire from cylinder temp switch feeds thru cover plate, i need to get this wire out of the way so i can install new gasket on cover plate for thermostat. THANKS
F_R
Honorary Supreme Mariner
You didn't say which 2005 Johnson you have. But I'm guessing the wire goes to a plug which won't fit through the hole, am I guessing right? If necessary, the wire can be removed from that plug. You are supposed to use a special tool to do that, but you can improvise and push it out somehow. Squirt some alcohol on it to lubricate it to make it slide easier. Other option is to pull the sender out of the head, but you risk destroying it by pulling on the wire.
amaziing1
you hit the nail on the head thank you very much...... i was wondering if i could slice the gasket so i could slide the gasket around the wire would this harm the gasket.
And Thanks Again,
