Need Help with year
davsboater
Could someone help me with finding out the year for a 15hp force the
model # 152F6A. Also i think i need to replace the rings it only has 85psi
in both cyls. do you know were is a good place to by parts for this engine?
thanks larry
flatcat77
Re: Need Help with year
what is your serial number? its right next to your model number on the plate on the inside cowling of the motor by the latch
jerryjerry05
As far as a rebuild.The compression needs to be taken with a good guage. Those you hold in the end aren't worth anything.The compression should be even or close.If both are really 85# then the head gasket is probably bad.
If you can't get parts on this site then boats.net will have what you need.
Look on e-bay too.J
