need help with trim on 85tl79r
Papa Ron 1962
Hi everyone, i need help with my trim. here is what is happening. i can hear the motors running both up and down when i press the button on the handle. the motor will move a bit up but when i release the button it goes back down right away. almost like there is a bleeder screw loose. The motor doesn't go all the way up it just moves a bit. then when i have the motor raised up manually and locked in the up position i raise the tilt up with the button and the rods stay out unless i push them in manually. Where would i begin to look and also where is the fluid fill located at
