LRCXed
Thread starter- Joined
- Sep 21, 2012
- 13
Hello everyone,
I've looked around the forum all morning and don't see the answer I need. I have what I think is a 70 or so Glasspar 16' Citation w/120 Mercruiser IO. I completely restored the entire boat from the stringer up as well as rebuilding the motor and electrical system about 13 years ago. The boat didn't get used for most of those years due to work and other issues, but it's back on top of my list again.
Two weeks ago I serviced the fuel and cooling systems, and took it out for a weekend. The only issue was that the tilt system isn't lowering the outdrive. It does operate with the switch on the controls, but only when I hit the down switch. Up stopped working while I was srevicing the boat. Probably due to a connection, and I'm cleaning all that up right now.
My main concern is that I have been using ATF fluid in the pump, and reading through the books I have says to use 10-30w motor oil. Can anyone confirm what I should use while I'm servicing the pump?
I do have a bit of seepage around the lines and rear plate. I would like to rebuild the lockout switch too. I think that's where it's coming from. I found one of the O-rings for it at a local boat shop. But will have to get into it to see if I can find the second one when I see what's in there. Any advice or opinions on rebuilding that would be much appreciated.
I'm not new to forums, so I'm going to try to post a few pics next so you can see what I'm working with.
Thank you in advance for any help and/or links that will help me through this.
Larry
Larry
