Need help with steering cable.
redneck joe
I agree. Now finding one that is 8 ft long.,that is the problem. Anybody have any suggestions where to find one?
no. I looked a bunch this morning...
I'll keep looking.
On shift cables, I have just added a loop but I think the sterring cable might be a bit too stiff?
redneck joe
can you squeeze a 10 footer int here?
No the 8 ft is actually to long as is.
I had about a 6' cable in my hellion . That was a special order vs finding on the shelf
You need to look at the manufacturer catalogs, then search by part number if the size is readily available retail, or custom order. For short cables, it will most likely be custom order. Unless your dash and bow area allow a large sweeping coil and you can get into a 10-12' cable
Try a local lumber yard or sawmill; they often have longer stock or can order 8 ft pieces. You may also be able to buy a longer length and cut it down.
How does this pertain to the steering cable the OP needs in 8' long?
