need help with shift rod adjustment for a 84 evinrude v4 90hp
forty5goingon65
my manuale only goes to 1982 it says measure from the top of the bottom end to the centre of the hole on the shift rod at 21.844 inches which i assume is about 21 7/8 roughly but it does not say if in forward, reverse or neutral but neutral would make sense to me does any body know if the 1984 would be the same measurement as the 1982 and do i measure it while in neutral thanks
boobie
Re: need help with shift rod adjustment for a 84 evinrude v4 90hp
Measure it in neutral. Your spec sounds correct.
forty5goingon65
okay thanks for the help i will try that next weekend when i get home from work thanks againg
