Need help with Prop Choice
Dacar92
Hi guys,
I have a 24' 2000 Manitou pontoon with a 90 HP Johnson outboard. I need to get a new prop but there is nothing on the prop to indicate the pitch. It is a 3 bladed prop and the only stamped numbers or letters on it are D52B. That's it. Is there a standard used for pontoons and 90 HP outboards?
I pull kids on tubes, other than that it is just a cruiser.
Thanks in advance.
Dacar92
Re: Need help with Prop Choice
For some reason, my edit to the OP will not submit.
EDIT:
I found a couple other stamped items. On the inner hub there are two set of numbers:
391668
14 X 13
Dacar92
I assume that one is an OEM part number
391668
and the other is the diameter and pitch. Is my thinking correct?
Thanks
jestor68
391668
Thanks
Yes. The 14 X 13 is the diameter and pitch.
What WOT rpm does the motor achieve using that prop?
Dacar92
Hi. Thanks for the reply. I have no idea about that answer. The boat does not have an RPM meter. Plus, it's winterized and the prop is at my house. Not on the boat.
Are you asking to help optimize my prop choice? If so, thank you. However it seems I have no choice but to replace it with the same type.
Would one of these be the right choice?
13” Pitch Evinrude Outboard Boat Propellers 90 HP 1981 & Newer - iboats
Thanks
jestor68
For what it is worth, I had a 24 ft pontoon boat with a 90 HP Mercury motor.
It turned a 15" pitch Solas aluminum prop at 5400 WOT rpm.
steelespike
A 13" prop is a reasonable selection.
it is important for best performance and the health of your motor to have a tach.
Also good to have a gps for speed. your motors wot rpm range is 5250-5750.
The motor should be propped to operate within that range at wot, even if you mostly only cruise.
Dacar92
Thanks very much for that info. I can install a tach next year in the Spring. I'll have to get a 13" this winter and I will monitor the WOT during the summer. Go for this one?
Solas Amita Aluminum Boat Propeller #2411-138-13 for Evinrude 90 HP Outboard 1981 & Newer - iboats
Whats the difference between that one and this one? Besides the little bit of diameter? Will I notie any performance difference at all?
http://boatpropellers.iboats.com/Ev...-138-13_Propeller/86/20288/?*******=608717241
steelespike
These are esentially the same prop.
The Rubex has a separate hub. If there was a bigger difference in diameter I would go for the larger on a pontoon.
A few months ago there was a discussion here regarding the hub getting stuck in the prop
making it sometimes a difficult for in the field replacement when changing for water sports etc.
I guess if you were inclined to want to fiddle with different props you might be able to try a Merc Rubex prop on your Johnson.
And of course if you wanted 2 or 3 props for specific use you might be able to save a little.
jestor68
Mercury calls there's Flow Torque. Solas is Rubex. Michigan is Vortex.
And yes, I assumed that you were interested in optimizing the performance of your boat.
Since you cannot know if the prop that happened to be on there is the correct one, a tachometer needs to be used to determine the correct one.
I suggest you pay a visit to a local marine dealer and request their assistance in determining the correct prop. They should agree to go with you, using their shop tach to select the best prop; provided you purchase the prop from them.
As a retired marine service manager, I have done this numerous times for our customers. You'd be surprised how many times that the prop that came on a boat was not the best choice.
Your target rpm range is 4500-5500 rpm for a 2000 Johnson 90.
