pasportsman
- May 22, 2004
- 4
I have a 1998 Johnson 48hp Ser. No. G03976934.<br /><br />On my last trip out, my speed was not what it should be 13mph....I usually get 25pmh. Last year I had a powerpack problem and thought it was the same problem, but I have checked the engine and it is running great.<br /><br />I then started checking the lower unit and found fishing line wrapped around the prop shaft. I check the oil and it has water in it. I know I need to change the seals on the shaft, but will new seals and oil fix the problem? or Does the loss of speed mean that I have more internal troubles and need to do more work.<br /><br />I have a Seloc repair manual for the motor, but the lower unit looks quite complicated and I only want to tear it apart if it is necessary.<br /><br />Any help I can get will greatly appreciated.<br /><br />Thanks
