Typically if a motor runs good when cold air only youbare too rich. Cold air is denser and can carry more fuel. The warm air does not have the molecules to pick up all the extra fuel. Lean the bleed screws or find the orifice you left out when you "rebuilt" the carbs.
but we really need spark check numbers ...
Yes they are all open and stay open during mid and full throttleVerify choke butterfly open fully and stay open at mid and full throttle.
I don’t have a factory manual, how to I go about verifying link and sync and timing?Well shoot...
who cleaned carbs? Experienced? It's not rocket science but some fail to remove all jets and clean.
heat soak can cause electrics to act wonky. Goto Cdi electronics .Com and use their free trouble shooting guide.
Have you verified that timer base moves freely through the whole range?
do you have a factory manual? Done the link and synch? Verified timing?
I recall you replaced coils? What color wire goes to the top and bottom? Hint top gets orange with blue stripe. Bottom gets orange with green stripe.
all parts replaced with OEM?
that's really all I got for over the nets help. Plus I haven't seen one this old in years, i quit turning bolts on the old ones...sorry.
we are probably back to the low compression but they usually don't start well or idle well with low comp.
You use a manual. 17 or 18 steps for that one. You can try searching my old posts, I wrote it out once, it was for a 140 but it gives you the general idea.I don’t have a factory manual, how to I go about verifying link and sync and timing?
This probably sounds crazy, but do you know where I would get a manual?You use a manual. 17 or 18 steps for that one. You can try searching my old posts, I wrote it out once, it was for a 140 but it gives you the general idea.
You might wanna try a good compression guage or pop the head off before you sink any more $$$ in this. It's real old. Things don't last forever and can get pricey.
Yes I do realize that and thank you. I posted the compression test back on 1st page, test 100 on each cylinder ... haven’t done a fuel sample didn’t realize that needed done. But will do and post results as soon as I can.The only suggestion that I have is to do systematic troubleshooting. That will eliminate non-problems and get you to the root cause.
If you "didn't test anything" you might end up just throwing parts at it....like 3 new coil packs....
That gets expensive.
In post #16 you said..."I will give all these things listed a check and give you all updates".
We are at post #34 and I haven't seen those updates.
You have viable spark....and apparently, 6 serviceable coils; twice as many as you require.
That still leaves compression and fuel.
Those checks have been suggested repeatedly. We can't do them for you.....
