hydrasport15
Thread starter- Joined
- Jul 3, 2015
- 8
Hey guys i have a 95 johnson 175 fastrike. Took it to the lake yesterday and had a malfunction... motor fired up as usual, idled fine, ran on plane fine... now the problem, fished for half hour or so and went to start and nothing, motor would just crank and nothing... primed the bulb until tight, and same thing.. tried choking it with key and same waited about ten minutes thinking it was flooded and started trying again.. finally after milking the hotfoot, i finally got her fired up and put it on the trailer.. i put it on muffs at home and same problem.. i have check all fuel lines and everything seems to be clear and free. I noticed when your trying to start it, it seems like the choke isnt working when pressed in but you can kill the motor when you do get it running and choke it.. it has me puzzled... the carbs were rebuild beginning of last year with new bowls on each of them.. any help would be appreciated.... thanks
