Need help with impeller and hub PLEEEASE :)
freekshow
Thanks for reading, I am new to boats and have recently purchased my first one...I need some assistance regarding locating a through exhaust hub for a stainless steel propeller I recently purchased. I have a 1988 MAXUM with 85 HP force MOTOR. I am looking for a hub to fit the prop and have not had much luck searching the web so far. The prop is a 13 3/4x15P and the closest Michigan number I guess is #73002 ssc-315c ......If anyone can assist in where I may find a hub to fit this I would greatly appreciate it. I am also looking for an impeller for the 85 hp Force motor also that I am having difficulty locating...thanks again for any help you can offer
rickdb1boat
Re: Need help with impeller and hub PLEEEASE :)
We will need the serial number off the transom bracket or motor to find the correct impeller. Also, what kind (Brand) of prop did you get?
freekshow
thanks,<br />the prop is a Michigan brand with the numbers <br />65C-315-II-C on it<br /><br />the numbers off the motor are :<br />model # 856A8B<br />serial # 1086<br /><br />THANKS FOR THE QUICK RESPONSE AND HELP :)
rickdb1boat
I have to admit I am a bit lost on this one. If you have a michigan prop, it has through-hub exhaust already. What exactly do you mean by hub? Are you referring to a spacer? For example, a Michigan prop would have a number like 073008 or something like that.<br /><br />Propeller Type: Outboard<br /> Manufacturer : FORCE, CHRYSLER, U.S. MARINE<br /> HP / Model : 85 HP SINGLE EXHAUST UNITS<br /> Year : 1988-1989<br /> Boat Size : 16'-20' BOATS - ALL LOADS, SKIBOATS<br /> Material : STAINLESS STEEL<br />#073008<br /><br /> web page Water Pump Kit # 75
rickdb1boat
Maybe this will clear it up: If is truly the hub you need, a visit to the prop shop is nessesary..<br /><br />
freekshow
sorry that I am an idiot when it comes to boats so far, but i AM learning alot from this forum, you guys/gals are a great wealth of info :) <br /><br />I need the guts on the inside of the prop. When I received the prop, it has a BIG hole in the middle with nothing there, when I look at the prop on the boat now, it looks like there is a "bearing or spindle assembly " that makes the prop sit tight on the shaft. Right now if I were to put it on, It would be real, real loose with gaps on each side of 1/2 inch...I hope i am making sense to someone, sorry
rickdb1boat
You need to take it to a prop shop. They can fix you up..<br /><br /> Hub
