need help with force 150, and boat questions
wfenris
These links are to some BAD picture of my boat, just wanting to see wha you guys think....if a 150 is ok for my boat, i was told it would be.<br /><br />Also the compression came out at 145 - 150 psi with the engine cold. sound right ?<br /><br />the picture is on my girlfriends acount here is the link....<br /><br />www.geocities.com/snow_whites_lesbian_lover/index.htm
horndog
Re: need help with force 150, and boat questions
link is dead, your girlfriend is a snow white lesbian?
horndog
there should be a uscg tag in there tell you max HP, all hulls should have that, if not, go to a uscg and have them certify it
wfenris
i am in canada for one, but i have not seen any tags on the inside of the boat....<br />Anyone have any ideas of the exact type of boat this is so i can try and search the net for information about it..?
sloopy
I'm just wondering about that lesian thing!
plywoody
Somewhere on the boat, near or on the transom, if it is a commercialy built boat, there is a tag from Transport Canada that lists the max power rating for the boat. It is probably not listed in HP, but in some sort of metric measurements. For example, my 17 ft Crestliner, sold in Canada, is listed as max 30 KW. I run a 50 hp on it comfortably.<br />Leave it to the Canucks to have standards that make no sense, of course, and I have no idea how to translate kw to HP, but perhaps someone at Transport Canada, or the Canadian coast guard, could help translate it.
wfenris
ok well there is nothing there, i think it might have been a kit boat, or else the tag has just fallen off over the years...
revertmastec
Sloopy,<br /><br /> I'm with you on this one. :p
