Re: NEED HELP WITH EVINRUDE MOTOR
Hi Hellen<br />There are probably three main things that cause this. #1 Exhaust leak, You may have a seal or gasket leaking allowing exhaust to be traped under the hood suffacating the motor.#2 Loose sound blanket/s cutting off air to the carb. #3 Electrical short, your spark wires may be shorting to a latch, etc. Look for any wires that may be a problem. My Guess, with this model, Exhaust leak. Where? Where the shift wires decend into the exhaust housing, also there is a large rubber seal at the bottom of the inner exhaust tube (this is probably where the problem originates). If you have the mechanical shift model that's ok, same idea only diffent.
