NEED HELP WITH EVINRUDE MOTOR
helen deaton
I HAVE A 1968 85HP EVINRUDE MOTOR WE BELEIVE IT HAS AN EXHAUST LEAK BUT WERE NEW WITH BOATS WOULD ANYONE KNOW WHERE THE LEAK WOULD BE COMING FROM WHERE ARE THE GASKETS LOCATED AND ETC. WHEN THE COVER IS OFF IT RUNS FINE WHEN ITS ON IT LOSES POWER BIG TIME IF ANYONE KNOWS PLEASE LET ME KNOW
grizzlybars
Re: NEED HELP WITH EVINRUDE MOTOR
sounds more like an air supply problem, make sure that air intake at lower front is not blocked by something
JB
Hi, Helen.<br /><br />Did you get the Repair Manual we advised you to get when you last posted this question?<br /><br />I recall that Joe Reeves also offered advice.<br /><br />Believe me, Helen. You need the manual.<br /><br />Good luck. :)
Walker
That model 85 has a habit of shorting the spark plug wires out on the hood latches. Route the spark plug wires where the bottom wire makes a loop upward then down to the spark plug. Do this on both heads and be very careful when you put the cowling bake on to not catch the wires.
alcan
Hi Helen<br />Everybody here would love to help you with your situation. You have been given most all of the possible causes that I can think off. You need to communicate to us how you have determined or ruled out complecations. Did you rule out the hood latch idea? How? How do you know the problem is an exhaust leak? Did you preform a smoke test? Does your model have electric shift? Did you look for a leak where the shift wires decend into the exhaust housing? I could ask you questions all day long. If you don't know what I am talking about,it is fruitless.
SeaMasterZ@aol.com
seems as tho that IS a common thing, according to the posts Ive read, the exhaust fills the cowl, and effectively chokes the motor out<br /><br />that being said, alcan has guru status on here, give him enough clues and hell solve the case, a regular Sherlock Holmes<br /><br />Quick Watson! The game is afoot!
helen deaton
I WANT TO THANK EVERYONE FOR THE ADVICE WE FIXED THE EXHAUSTE LEAK AND IT RUNS GREAT JUST GOT BACK FROM THE LAKE THANKS EVERYONE
Solittle
Helen - Maybe you coud tell us a tiny bit about what you found and what you did??? We won't tell anybody else if you like.
