Need help with carburetor project (2007 Johnson 4stroke 15hp)
pillars
Hi,
Engine Model is J15R4SU.
Engine only runs with the choke out and dies when you push the choke in. Based on some research this seems to indicate a problem with fuel supply, either filter or fouled carburetor. I cleaned the filter out but there was nothing in there anyway. So I took the carburetor off and disassembled it. However, the issue is that I seemed to have ordered the wrong carburetor repair kit. I ordered OEM 18-7219 / OMC 439073 which according to some websites should fit that engine model. But the parts in this kit don't seem to fit the carburetor I am holding. They are slightly smaller (example float valve) and the gaskets are not a match. I am looking at this carburetor:
https://www.boats.net/catalog/johnson/outboard-by-year/2007/j15r4sub/carburetor
but I can't figure out anywhere I can order a kit for it.
Please help.
