Need help with battery/switch/isolator/stereo install
Straightshot7
Hi I just bought a boat it's a 78 cobalt ski boat yea it's old lol but it's my first boat, ok now I'm into stereos for cars I know a lot about them but it will be new for me to put one in a boat, this boat needs a new stereo. Ok my questions are the boat right now has 1 battery with no switch, I'm wanting to put 2 optima blue top deep cycle battery's in and I'm wanting to run 2 amplifiers for the stereo now I want to put them on a switch to 1 battery for The stereo so I can keep the other battery for starting I also want to use a isolator now I'm not sure how to wire this all up right cause I never used a switch before anybody have a wiring pic or diagram I can go by I also plan on upgrading all charging wire to 1/0 for
Better charge like in a car called the big 3 can I do this in a boat to thanks
Silvertip
Honorary Supreme Mariner
Re: Need help with battery/switch/isolator/stereo install
What would you do if this system was in a car? Wouldbn't you have the same issue?
Straightshot7
Well not sure I'm just needing to know how to wire the dual batteries up to a switch and how to hook up a isolator, I know how to do the stereo since its like a car I'm just needing to know the power wires and ground wires also would I run the
Amp wires to from the battery or switch. I'm not familiar with this aspect thanks
calvinator
I have two batts w/Blue Sea ACR model 7610. It isolates and combines. Check into it because it is transparent operation and nothing to fool around with. Used it all last year and batteries were always charged.
Batt 1 = Starting only.
Batt 2 = all electronics, VHF radio, fish finder. My stereo is 2000w Sony headunit with (2) Kicker amps, 4 spkrs, 10" sub.
