munchie2222
Thread starter- Joined
- Aug 19, 2012
- 12
I recently purchased a 1987, 16? Jason bass boat with 2 live wells and a bait well powered buy a 500 GPH Attwood Aerator pump which doesn?t work.
I have 2 livewells and a baitwell, the rear and front livewells both have drain plugs, aerator spray heads, and an overflow going out through the side of the hull.
The rear of the transom outside as per pick (10 outside)has three items through it. Facing the bow from the rear the first one Left Port Side is the Attwood Aerator pump, the middle is the regular drain plug, and the third starboard side I think is fill and drain hose for the live well?s because if I leave the drain plugs in the live wells out, they fill with water.
I have more pic?s if needed to give you an idea where everything is located in the boat.
If there is anyone who understands this system any advice would be greatly appreciate.
Thanks and have a great day!
Peter Bauer
Peter Bauer
