need help with a price.
Beagle Den
Ok I was looking at a 68 starcraft.18 ft with a cuddy, I/O 120 murc. it needs a complete tare down. at first they said they were selling because of too many boats. I thought what a great find and I guess it kind of is, I really like the look of this boat. they have about 200 lbs of weight in the front, they say its needed when trolling. it sits on a home made trailer no breaks, and looks kind of heavy. but no a real problem with that. they also said they bought this boat two years ago from a guy who had the motor rebuilt and then forgot to drain the water when winter hit and cracked the block, when they discover that they put one of those gunkes in it, it helps but still water get into the oil. so basically its had it in my mind. they want 2800 for it I know there not going to get it if the person is aware of the motor problem. So my question is what do you think its worth.
Sorry to have to repost this I should know just to come here.
Pugetsound
Re: need help with a price.
what area do you live in.? Makes a big difference in priceing?
Brenn
Where Pugetsound and I live then yeah people would ask for that type of money.I still wouldnt pay it,thats to high with it needing an engine.
starcraftkid
It's hard to say for an I/O boat, the motor is more a part of the whole package than is an outboard.
I've got an 18' Starchief with an outboard and there's no way I'd let mine go for $2800, but mine has new decks and a new transom. I paid $2500 for it with a decent trailer, rotted wood everywhere but a solid hull. Mine had a motor that ran, but it was tired and the tilt and trim was shot. I replaced the motor with a more modern outboard. If I were to list mine, It would be as a hull only, I'd keep my motor for the next boat, and most likely the trailer, unless someone gave me what I felt it was worth. Since you can't buy one of these anymore, to me that makes the price even higher. Even a junk aluminum boat is worth its weight in scrap aluminum, which in that case would be around $480 right now.
Mine also needed a complete repaint, which it really still does but I can paint the hull anytime.
If your after an I/O boat, then that boat may have more value to you than it does some others. Myself, I won't touch an I/O model, there's just too much to go wrong and it's too hard to change to a more modern motor.
With an outboard it's just a few bolts and a set of controls.
I passed up a 22' Chieftain that was basically in the same shape as what you describe a few years back, the guy wanted $200, and had no takers. The boat finally got given away. If that were an outboard, around here, people would have been beating down his door to get that boat.
I had thought about taking it and doing an outboard conversion but the cost of doing so and the fact that I really didn't want a 22' boat, I didn't bother. I had no interest in scrapping it either, figuring that someone would buy it and fix it up. I later saw it for sale for $4,000 with a new deck, new cabin wall, and no motor on a modern roller trailer. It sat for a few years but finally disappeared. The guy said he sold it for $2300.
As someone who buys a lot of boats and is always fixing, trading, and selling, I generally only buy boats that are really cheap, I pass on anything that I don't get for almost nothing unless I really like the boat or another isn't likely to come along.
I've bought aluminum boats for as little as $50, and as high as $4500, it all depends on the boat. The most important thing is to find a solid hull, one with no missing rivets, no dents, no corrosion, and not modifications. Paint, plywood, and other parts are cheap and easy to replace.
Bwana Don
Sounds like a whole lot for a boat that needs an engine right off the get go.
Beagle Den
Good Morning. Thanks for your replies. We live in Vernon BC. yeah if it was an outboard it would be in my driveway already. I found a motor last night that the guy has taken out of a boat that he rebuilt with a lot more horsepower. I think I will start out with a low offer and see just how interested he is in getting rid of it. I can find a decent boat for seven or eight thousand and if I give him what he's asking that where I will be when all said and done. Yes your right the only thing is that it will not be that same boat.
adamjr
Beagle, what happened? Did you get it?
Pugetsound
I realize that Canadian prices are higher but thats a lot for what seems like a complete rebuild Plus Motor.
elkhunter338
Master Chief Petty Officer
I would not pay that much for a total rebuild.
You are looking at $3k for a new motor, plus outdrive stuff.
then rebuild the whole inside.
The trailer sound not real good.
I am thinking $500 off the top of my head maybe $1000 if you are really looking for a 18' cheif.
