Need help with '95 40 HP Mercury motor
fishbuster
My dad is looking at a '95 Mercury motor, Power Trim, 40 HP, oil injected. Runs/idles fine for 5-10 minutes, then when in full throttle, runs half speed or less. Motor hasn't been used since '98, and even then was used very little. Fuel/fuel filter were replaced, Seafoam added to tank, carbs cleaned. Still having the same problem. Any ideas of what we can do next? Owner is willing to correct problem.
JB
Re: Need help with '95 40 HP Mercury motor
Howdy, Buster.<br /><br />Sounds to me like it is running on one cylinder.<br /><br />If the compression is good it can pretty easily be fixed, but it might be costly.<br /><br />Don't buy it as is unless the price is VERY low.<br /><br />Good luck. :)
