Re: need help with 270 outdrive
Hi Tim,
I had a couple of the 270 drives a few years ago and suggest you disconnect the inlet hose to the pump to verify that the line is open and clear to the outdrive. I am guessing you may have a collapsed suction hose that may open up if you pressurize it. I would use a garden hose to squirt it tlhrough to the stern drive suction poing. If you get flow, the raw water pump on the front of the crankshaft should get water to your engine.
Have you verifyied that the thermostat is not stuck closed?
erie_guy
