BloodStone
Thread starter- Joined
- Mar 13, 2009
- 33
Hello;
I was told (by Johny 25) that the tech heads here know more than at Tinboats.net.
Anyway, I posed the following question there & inadvertently started a mini-war between 2 guys. :fencing:. :facepalm:
Question about Evinrude Carb compatibility? - TinBoats.net
Question; I was needing to know if there is ANY fundamental difference between a 1982 E25ECNE Evinrude CARBURETOR vs a 1982 E35ECND Evinrude CARBURETOR? I've looked at exploded diagrams of both carbs & can't see very much difference between the two (besides jet & throat size). Are they interchangeable? I own the 25hp.
Question #2; If I can indeed put the 1982 E35ECND 35hp Carb on my 1982 E25ECNE 25hp motor what other stuff do I need specifically to do to make it work? If all is required is a new plate & fine tuning the 35hp carb, then great! If I gotta change a bunch of other stuff too (like LU, prop & exhaust ports etc..), then I'll forget about it.
Thanks in advance.
