need help with 1974-76 chrysler twin 60hp lower unit
matt1778
I have a 15ft 1968 montgomery ward sea king.It has a 74-76 not sure exactly but thats the only years they made them 60hp chrysler twin.It run's like a top now with a lil tlc.But the lower unit seems like it is leaking gear lube from the water intake.Does this make sense?I emptied the lube and there was mabey 10oz or so of caramel colored junk in it.No metal chips tho thank god.Could it be a bad seal or am I just paranoied.I have included some pics of the lower unit and lube.
tashasdaddy
Re: need help with 1974-76 chrysler twin 60hp lower unit
that is the water intake, probably old exhaust gunk leaking out. lower unit lube is an ugly color, and smells. refill the lower, after a couple of runs, check it. water will go the bottom and separate out. or will turn to chocolate milk shake, if check right after running, kind of foamy. http://forums.iboats.com/showthread.php?t=207285
matt1778
well thank you again.I'm going to put in fresh lube finish sealing holes and try to install the bilge pump today and put the boat in the water tomorow hopefully it geos beter this time than last time.Now that i have boath cylinders running trust me that helps.And with the holes filled mabey i can actualy catch some fish and enjoy a day on the water.I will check the gear lube again when i get back.Thanks again.
Frank Acampora
The only way oil can leak out the water intakes is through a bad seal. I am interpreting "Caramel Colored" as creamy colored. This means there is water in the gear lube. Uncontaminated lower unit oil will look either dark brown--but clear, or dark greenor possibly other colors if it is synthetic. In either case if it looks cloudy, then it is contaminated with water. If the oil on the outside has a unique odor, reminiscent of sulphur, then it is lower unit oil.
Since the oil is coming out the water intakes, the most likely culprit would be the top drive shaft seal (under the water pump). However, the season here is almost over and if it is the same for you, changing all the seals would be a good idea during the winter. It is not difficult.
However, if you run these engines in a bucket, a god-awful amount of used engine oil will collect in the water and get into everything, making you think you have a leak. So the first thing would be to smell it, then clean outside of the whole lower unit, then replace the oil. If it happens again, then look for a leak.
You can buy parts at The Chrysler Crew (Google) but they will be expensive. Seals and bearings on these engines were standard and can be bought cheaper at your local bearing supply store. Just try not to destroy the numbers on them when you remove them, and specify stainless garter springs. (because it is in a water environment.)
BTW: Chrysler made a version of the 2 cylinder 2 carb 60 horsepower engine all the way up to 1984. Later models had a different mid leg and a one piece lower unit.
