tyeechaser
- May 17, 2010
- 5
What is the rust colored piece attached to the carb? It has a rich/lean arrow on surface. Can the whole thing go into the carb cleaner and soak overnight? Lot of corrosion on this carb and needs a good soaking and clean up. Carb kit on the way. thanks for the help. I've done quite a few erude carbs but this one has me a bit baffled. thanks for the help. mike
