Need help with 10hp seahorse Johnson
1basser
Just inherited a Johnson 10 hp. Probally not ran in 15 + years. Thinking of rebuilding/restoring.<br />Need help with age/year, parts available where?? Is it worth restoring or just fixing up to use?Owners/parts manuals available?<br />Model: QD-24B<br />Serial #: 2384961<br />thanks for any and all help.
alcan
Re: Need help with 10hp seahorse Johnson
Hi Basser<br />You have a 1963 hp johnson. All parts are readily available.
rterrian
I have that same engine. When I got mine it needed a water pump and carb rebuild. I was able to get all the parts I needed from:<br />Lindenhurst Outboard<br />305 E. Montauk Hwy.<br />Lindenhurst, NY. 11757 or E-Mail<br />outboardwizard@aol.com
wayne h
Master Chief Petty Officer
i have 2 of them engine they are great little engines. napa has alot of the parts also.i have seen alot of then is use still even know they are older engines they are pretty simple. if you dont have a manual get 1 its worth every penny
1basser
Wayne, Boater2 and Alcan...thanks for the info...this should get me started. Still courius to know if the motor should be restored to original condition or just used?
rterrian
It's not a rare engine so use it. It's a great little outboard.
