graphicjunkie
Thread starter- Joined
- Jul 10, 2010
- 51
So I'm trying to get this evinrude to crank over on it's stand.
I've got most all of the wiring hooked up that I think is related to ignition.
When I turn the key to the start position, I hear a quiet buzzing sound coming from the solenoid here...but nothing else happens.
I've checked connections and ensured that everything is tight.
I unhooked the battery and checked to ensure that the starter could freely move, and it can. I forget, but isn't there some way to hot wire that solenoid and by pass it?
What am I overlooking or doing wrong?
Here are a couple of other pictures to hopefully answer any other questions you have.
Right now I'm not supplying any fuel. I just want to see if I can get it wired to crank over and then I can video checking the compression. From there I will try and get fuel to it.
In this picture, it shows the neutral safety wires in yellow/black. They are currently connected to satisfy that safety...as well as the engine IS in neutral, verified.
The red wire coming off the circular object, I have no idea, but it is hot ignition only. (someone feel FREE to tell me what that is!....PLEASE!)
The gray wire heading off the top of the picture, I don't know either.
