jonboatbassin
- Jan 3, 2003
- 63
I went to hook up my boat this weekend and while I was lowering it onto the ball the trailer buckled about 5ft from the end of the tounge, right were the from winch post is mounted to the frame. <br />Im not too worried about fixing it at the moment but I need some ideas of how to unload the boat now? <br />Ive tried getting behind the boat w/ my truck with the trailer wheels blocked and couldnt pull the boat off!! It was kinda muddy so i ended up spinning all 4 till I was almost stuck in my yard.<br />The front end is now full of water under the deck since it is angled down in the front and ofcourse no drain plug to pull. It is way to heavy to pick the front end up without a jack but I cannot get a jack under the trailer far enough forward to raise the fron end. I got a jack as far under it as I could and it was just raising the back end due to so much weight in the front.<br /><br />I really need some help here guys. How can I get the boat off the trailer?
